I have the connect ap. Works great.
The amps graph gives a net result of amps in minus amps out. I would like to know amps out only. I want to know what the total amps needed for the system regardless of any amps in. I would like to determine this ahead of time for night sailing where there is no power generation as well as general knowledge of my system. It is about impossible to just look up the amp draw of each item running as they dont run continious, especially the large draw of the refrigerator.
Thank you
Then connect the minus of the charger to the battery, not to the shunt/ground.
or connect the charge sources to the battery through a separate shunt…
However, if you integrate a GX device into the system, then the overview gives you a nice view of all the currents in the system.
I do have a cerbo gx
You saying I can get the info I want with that?
yes, if you have all your equipment - inverter, solar charger, shunt connected to the cerbo.
