Connect 2 different batteries on cerbo GX?
Can I use 1 battery on a VE-CAN port of the cerbo GX and an other model of Battery on the second VE-CAN port ?
Hi @YonneSolaire
Glad you signed up here.
Only one BMS can be connected via VE-CAN.
You haven’t written much about which batteries you want to connect together, but have a look and see if the software helps you with that.
Otherwise, just search for serialbattery on the forum as well.
Good luck
Thank You for you answer : To be more clear, I was meaning I want to connect 1 Pylontech LFP US5000 on one VE-CAN port (setting the port as CANBUS 500kbit/s), what is running fine actually …and add an other battery (Dyness LFP Powerbrick 16 kWh) on the second VE-CAN port (setting as CANBUS 500kbits/s)… The Cerbo GX has 2 VE-CAN ports and we see them in the software configuration …
This is not possible ?
You can, only if you want to overcharge your Pylontech or undercharge your Dyness and only one of them can be closed loop the other open loop and not connected, but don’t expect anything good to happen mixing them.
15s cells vs 16s are not really a good idea to mix.
OK so there is no way to do that …because of the Venus OS software ?
What is 15s & 16s ?
The charging voltage of a 15-cell battery (15S) differs from that of a 16-cell battery (16S) … operation is certainly possible … but if you want to fully charge and balance the 16S battery, the 15S battery will display an error because you’re exceeding its charging voltage … It’s missing a cell. In the best case, the 15S battery will disconnect via its BMS (Battery Management System) … but nobody would recommend doing that.
It’s like a table with two legs of different lengths … you can eat at it … but it’s not recommended :sweat_smile:
What is the link beetwen this and my 2 batteries 4,8 and 16 kWh ?
Hello @YonneSolaire,
I think it’s being assumed that you want to connect the two batteries in parallel on the DC side via a busbar or something similar.
Are you just asking whether the Cerbo can manage the two batteries’ BMSs separately? But would the batteries be charged separately, without combining their voltages?
To be honest, it’s a little confusing without knowing more about the system or what you’re trying to achieve.
Regards,
Basically the answer is still no, you can connect them, but then you can’t charge one battery with the same Victron system components or connect the two batteries to the same DC system, so there is no point. Just get another Cerbo for the second different Voltage battery.
Oh, with a second Cerbo it may be possible , even if the 2 batts are on the same DC wires ?
Good evening, Dyness offers a solution combining a 48 V battery with a 51.2 V one, with #Dyness Buddy – Flexible parallel battery extension for 48 V and 51.2 V energy storage systems#, to see whether it is cost-effective.
No, sell one of the batteries and buy one of the same voltage if you want them on the same DC bus.
Think about it for a second, they are different Voltage batteries, if you connect them, one will overcharge or one will undercharge. Try connecting a 12v battery and a 24v battery together.. not a good idea.
Edit* the Dyness Buddy only works for Dyness not Pylontech, and it’s unlikely to be a good solution
Yes, selling the old battery was the first plan… ans we will keep it. Thank you
no, it isn’t really practical to operate
The comparison with the table is good, but not sufficient
It’s more like a table where one of the 4 legs is shorter
To keep the two batteries, you’ll have to use them separately. One solution is to use two inverters: one with one battery and the other with the other battery. If you want, you can pair the worse battery with a cheaper inverter, as a secondary inverter.
You can connect that inverter to the main inverter’s AC In input or its AC Out output. Alternatively, you can use a DC charger from the cheap inverter’s AC output. You need to take into account conversion losses, and work out the payback and costs of each solution.
Another solution is to use a voltage converter to charge the battery you care about using the one you care about less, regulating the voltage and the direction of charge.
But unfortunately, you can’t directly connect two batteries with different voltages.
Personally, I’d consider a solution with a second inverter, which would also give me a backup system. Two different inverters with independent battery systems, and perhaps even some panels too. Then you can connect them via AC in whichever way suits you best.
Regards,
It’s not a solution we’d recommend; one can end up disrupting the other.
Some run it without any problems, but others experience intermittent outages.
Hello @thierry_cortassa,
Which of the solutions is worse and tends to cause more problems? What should I pay more attention to in order to avoid problems, or what are they usually caused by?
I’m very interested in the couplings, as I’d like to make use of batteries from other brands and with different voltages from the ones I currently have, as also mentioned in this thread.
That’s why I’m looking into the different ways of connecting inverters, whether by AC In coupling, AC Out coupling, or chaining them.
I don’t know if you can add any more information. I’d be grateful.
Thanks in advance,
Regards, :waving_hand:
