“Rat’s”.
Back in December, I had A rat. Bring me a very beautiful Christmas gift. He decided that he was gonna make a Jacuzzi underneath my solar panels. So he proceeded to build a nest by chewing the installation off of one of the wires coming off the back of my solar panels.
I had two vitron Charge controllers. 150/45 Network together, feeding my 24 V, 600 amp hour. Battery bank well, when it started raining in the middle of December. He had turned his brand new nest into a Jacuzzi. A week later, after the rain.
When the everything got dried, I tried to restart the system, but it wouldn’t, so I dismantled my entire system first thing that I found was the failure of one of the 2 charge controllers I had.
3 panels in series connected to one charge controller. And I had 6 panels connected in parallel to the other charge controller, and they’ve filled my bank up. Well, this charge control, it was in running the 6 in parallel, lost all of mast chips.
They’re all just burnt fell apart when I opened up the the controller to see to fix it.
Well, May 10th the other victoron, finally stumbled and fell out so out of the 9 panels. 5 of them were damaged. I had 2 panels that had the flat ribbon melted in between the the cells on the panel itself. And it was 3 other ones that just needed the diodes replaced in the back of them so I did that.So now I got 8 working panels and no charge controller.
So what I was kind of hoping is that one of you guys could help me pick out a charge controller.I have one coming in the mail.
It’s 100/30. I was really hoping that I could show you guys
The information from my panels to see how many strings of 2I can connect to this new charge controller.
It being is significantly smaller than the ones I had right now, there’s no money and I needed the power. So here goes the info about the panels.SHARP
SOLAR MODULE NE-165U1
CULUS PHOTOVOLTAIC MODULE
ELECTRICAL CHARACTERISTICS ARE WITHIN ±10 PERCENT OF THE INDICATED VALUES OF Isc, Voc, AND PMAX UNDER STANDARD TEST CONDITIONS IRRADIANCE OF 1000W/m², AM1.5 SPECTRUM AND CELL TEMPERATURE OF 25°C)
MAXIMUM POWER
PMAX 165.0 W
OPEN-CIRCUIT VOLTAGE
Voc
43.1 V
SHORT-CIRCUIT CURRENT
Isc
VPMAX
5.31 A
RATED VOLTAGE
IPMAX
34.6
VRATED CURRENT
4.77 A
LMAXIMUM SYSTEM VOLTAGE
600 V
MAXIMUM SERIES FUSE
10 A
FIRE RATING
CLASS C
FIELD WIRING
COPPER ONLY 14 AWG MIN. INSULATED FOR 90 C MIN.
SHARP ELECTRONICS CORPORATION
SOLAR SYSTEMS DIVISION
5901 BOLSA AVENUE, HUNTINGTON BEACH, CALIFORNIA 92647
