I was finally able to commission my installation last Friday, 9 October. It involved taking over and bringing the previous owner’s installation up to standard.
You can find the installation diagram below:
However, I’ve noticed that a very large proportion of my solar generation is being fed back into the Enedis grid instead of charging the batteries.
For example, today at 11 a.m. the solar output recorded by the inverter was 2797 W.
In VRM, I see the following:
And at 1:12 p.m., the ratio is even worse:
Overall, one third of my total generation is used to charge the batteries, 10% is consumed by the house, and the rest is fed back into the grid.
This is something I’ve noticed from the outset: the batteries aren’t fully charged when generation stops, and a lot of power is being fed into the grid.
I’ve also noticed that my two Pylontech batteries aren’t at the same charge level. The master battery is always “two lights” ahead of the slave.
As I’m very new to the Cerbo, could you tell me whether this is normal operation or whether I’ve configured the Cerbo incorrectly?
Here’s what I have in the charge control settings:
However, in the battery settings, the CCL is limited to 20 A, whereas the maximum charge current is 100 A:
Thanks for your help, and have a lovely day.
Derry
