Communication between inverter and battery
Good afternoon, I have an FZ Sonick salt battery, 48TL 200. I’d like to install another one. But according to the installer I contacted, communication between the Victron and the batteries can be problematic when there are two. Does anyone have experience with this kind of setup?
Have you read the manual? A quick look seems to indicate multiple batteries can have their communication cables daisy chained together just like any other battery with comms. Take a look. The manual seems fairly comprehensive.
Thanks for your quick reply.
Yes, that’s the theory, says the installer. In practice, things are different—or perhaps the real-world experience with a 2023 battery is different. In any case, I hope someone with a case like this will respond.
Use the Search on this forum - there is considerable discussion about these batteries.
There is almost no information from the manufacturer: https://saltbattery.horien.com/prodotto/tl-range/
so you probably have to contact one of their dealers that understands Victron.
