I have a few questions regarding our planned Victron setup:
1) Remote shutdown via Cerbo GX
- Can we turn off the Victron system remotely using the Cerbo GX?
2) Wind generator as AC source (no battery charging)
- We plan to connect a wind generator as an AC source to the Victron Multi (with Cerbo GX).
- Can the system be configured so the wind generator supplies AC loads only and does not charge the battery bank?
3) Generator operation without battery charging
- Can we run electrical loads directly from the generator (manual transfer switch) without charging the batteries, if the generator cannot support both loads and charging?
- We would run the generator only long enough to power essential loads, then rely on solar to recharge the batteries.
4) Cross-charging between two Victron systems
- We have two separate Victron systems with separate battery banks.
- Is it possible for System 2 to charge System 1 when System 1 is low and System 2 has enough charge?
- If yes, what is the recommended method?
- Can this be done without sharing a common battery bank?
5) Remote temperature monitoring & alerts
- From remote monitoring, can we view the temperature of the inverters and/or batteries?
- Can alarms/notifications be set up to alert us if the system gets too hot?
- If yes, how are these alerts delivered (SMS / email / app)?
Please confirm whether these scenarios are feasible and what equipment/settings would be required.
Thank you.
