CFE5100 BMS communication
i have installed 2 cfe5100 batteries. shows as two batteries with pylontech bms.
any help?
Did you check the DIP switches and Address switch are set properly, so that one battery is the “master”?
What are your switch settings
These are correct, and the system does recognise that a battery is present. The capacity is correct too.
The system identifies it as a Pylontech, so not all the information is correct, such as the SOC, voltage and temperature.
