Looking for a technician in the Palermo area
Hi everyone,
I have a system installed on a houseboat (solar panels + battery storage), but since switching from a Pylontech battery to Basengreen batteries, I haven’t been able to configure the system properly (Victron MultiPlus II 48/3000/35 inverter + 2 Basengreen BR-RM-LV 11.77 kWh batteries).
I’m looking for a technician who can help me in the Palermo area. Does anyone know any good people in the area?
Thanks in advance
Have a look at “Where to buy” on Victron’s website. Or ask at the harbour about an electrical service.
Thank you Karl-Heinz,
I’ve done it
(but I’m still waiting for answers)
What have you done? What problems or questions are there?
If you have the battery datasheet, switching it over is no problem.
The problem is that I can’t get a balanced charge and bring both batteries to 100% SOC, with the +/− cells at the same voltage (56.00 V?), without triggering an alarm (OC). As a result, when I discharge them, the voltage is too low and the inverter goes into protection mode and shuts down.
Is the battery connected to the CAN bus and recognised, or do you have a GX device as well?
The Basengreen batteries are probably BR-RM-LV models with 16 cells, while the Pylontech batteries have 15 cells, so you should adjust the Multiplus settings accordingly.
Otherwise, use the “Keep batteries charged” function to fully charge the batteries and balance the cells.
The FAQs describe the steps to take in the event of overvoltage. You just need to adjust the voltages for your battery, as it has one extra cell.
Hi Dirk,
sorry for the late reply, but I’ve been away for work…
Yes, the battery is connected to the CAN bus, and there’s also a GX device.
The Basengreen batteries have 16 cells, but I’m not sure how to configure the MultiPlus (the batteries are charged now, but if I disconnect the mains, they won’t carry the load). Which values should be set on the inverter?
Thanks in advance
You need to adjust your battery settings in the configuration menu.
Bulk, Float, etc. are usually specified in the battery manual or as Victron recommendations for a 12 V battery (“48 V”, i.e. 16s, means the 12 V value × 4).
(A hypothetical full charge for 12 V would be 4 × 3.5 V/cell; for 48 V, ((4 × 3.5 V/cell) × 4), so 56 V.)
Have you got the Mk3 interface?
Yes, I have the Mk3 interface.
What does the DVCC show, or rather its parameters CCL, CVL and DVL? Is the battery allowing discharge? What does the DC voltage do when it switches off, does it only sag (so likely hitting an undervoltage protection in the Multiplus) or does it completely disappear (so likely the BMS itself switching off)?
Basengreen is not officially supported by Victron, so most likely they are copying a communication protocol from some other manufacturer, or use a common BMS like JK. Then it depends on how well that is set up and programmed. Even without official support it should work, but theres no confirmation from Victron.
Hi @zuklic
Do you have the correct CAN bus cable for the new batteries?
At first glance, the cable for the Pylontech batteries doesn’t fit, as the pins are wired differently.
The manual also explains how the connector for the supplied cable needs to be wired.
Please configure your new battery for Victron according to the manual.
It should be displayed under Device Settings.
If necessary, check the CAN bus speed and protocol again.
It should look like this:
info@basen-power.com
Once all of that is working, the Multiplus just needs to be reprogrammed using the MK3 cable, but that’s not so important for now.
If all of this seems too complicated for you, please contact a Victron specialist who knows how to do this
https://www.victronenergy.de/where-to-buy
Hi Chrigu,
thanks for your help.
The parameter values are: CCL=320A CVL=56.30V DCL=400A
I can’t find DVL…
The DC voltage disappears completely when I increase the load (even with just 1000W), so the inverter switches off.
The BMS is configured with the values set by Basengreen, and the firmware is up to date.
What should I do?
Hi DirkW,
thanks as always…
The connections were made according to the manual (I had help from a trusted electrician), and at the moment the Cerbo GX display shows exactly the same screens you posted… that is, the grid status is OK, and the inverter and BMS seem to be communicating in both directions…
Reprogramming the Multiplus (I have an Mk3 cable available) — what values should I use?
ps
The thing itself doesn’t seem too complicated; I just can’t work it out because I don’t know the basics (what values should be entered, and why?)
pps
Incidentally, I also searched for technicians on the Victron website, but EVERYONE replied that since these aren’t batteries officially supported by Victron, they won’t touch them!
Well, that’s why you’ve ended up here, and we’ll see what we can find.
Well, what can I say…?
Thanks for existing!
I downloaded VictronConnect to configure the MultiPlus (I’m using macOS), I think it’ll work just the same…
It would be better to read the config once with Ve.Configure, as Connect doesn’t yet have all the functionality.
That will be the case in future,
don’t be surprised by the design of Ve.Configure — Opa is just a bit long in the tooth.
The problem with VE.configure is that it runs on Windows! (I’m on a Mac.)
Use an emulation program to get Configure working, or borrow a suitable device.
You’ll only be able to change some settings through Configure!
Ah… okay, I’ll download something now…
..after a little fight I got the app and I’m inside
