Cerbo Integration of 15SMT Solarmax inverter
I have a Mulitplus II and a Cerbo GX and want wo integrate my new Solarmax 15SMT solar inverter.
The inverter shows up modbus TCP via WLAN on port 502, but my Cerbo does not recognize it.
Is this a modbus protocol issue or anything else?
Is there any solution to integrate the inverter into the Cerbo?
Kind regards,
Klaus
The GX will only recognise supported inverters. You will need to do custom development, or use a meter like other unsupported devices.
You can try see if the new virtual device beta nodes in nodered can be used to get this to work, but failing that, follow the generic PV inverter setup guidance.
