which USB WiFi adapter with 5GHz band and WPA3 works with the Cerbo GX?
kind regards
Marcus
kind regards
Marcus
Have you checked the supported device list in the manual and looked up their specs?
BPP900100200 - CCGX WiFi module simple (Nano USB) → No 5 GHz
BPP900200300 - Asus USB-N14 → no documentation
BPP900200100 - Startech USB300WN2X2D → no WPA3
BPP900100100 - Zyxel NWD2105 → no documentation
BPP900200200 - Gembird WNP-UA-002 → no documentation
BPP900200400 - Netgear AC1200 / Netgear A6210-100PES
Hey Victron, are you kidding us?
There is only one supported WiFi USB dongle with 5 GHz available?
And the price is so disproportionate!! @BobHopman
There are others, the list is what has been officially tested.
Probably is cheaper to add a smaller 2.4ghz router for all the iot devices that 2.4 anyway. 5ghz is such short range.
Or [GIT hub] to load your own (How to install driver wifi 5ghz 0bda:b812 Realtek RTL8812AU/RTL8812BU Dual Band 1200mbps Wireless USB Wifi Network Adapter Antenna Laptop Ethernet 1000M Ethernet External · GitHub).
I definitely need a WLAN module with a 5 GHz band.
The 2.4 GHz band is far too crowded in this location.
The distance between the WLAN access point and the Cerbo GX is a maximum of 15 meters and there is a line of sight.
This adapter arrived this afternoon.
I’m testing this one right now.
root@nanopi:~# lsusb
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0846:9053 NetGear, Inc. A6210
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0bda:d723 Realtek Semiconductor Corp. 802.11n WLAN Adapter
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
WTF ???
