The relay is still shown in VRM even though the Cerbo GX relay is off
Hello everyone.
I’m using my Webasto with a Victron Cerbo GX. I configured one of the two relays on the Cerbo GX as an ON trigger and the other as an OFF trigger. I set up these controls in Node-RED and added them to the Relay screen. My problem is that, even though I’ve added an on/off control for Relay 1 using Node-RED and disabled the relay display on the Cerbo GX, the relay I don’t want still appears as active in the VRM Portal. I can’t turn it off from the VRM Portal.
The section I don’t want to see is the GX Device relays section. The Unused relay shouldn’t be visible.
As far as I know, a GX relay only shows up as a switch in VRM when its function is set to Manual. Node-RED needs Manual for the relays it controls, but the unused one doesn’t.
On the Cerbo go to Settings → Integrations → Relays (older firmware: Settings → Relay), open the relay you don’t use and change its function from Manual to something else, for example Alarm relay. Then it should disappear from the switches in VRM.
Only do this if nothing is wired to that relay, because in alarm mode the GX will switch it on alarms.
