Cerbo GX replacement
Hello, my Cerbo GX got damaged due to lightening. Getting a replacement. Is there a way I can retrieve the settings for the old Cerbo? I want the system to use the same settings.
Regards thanks
Unfortunately not, they need to be added manually.
Usually, there isn’t a lot to configure, it is typically quite straightforward to add the battery monitor, dvcc, ess etc.
Can I replace the Cerbo GX with this
No problem, it’s more or less a Cerbo GX and GX Touch screen in one enclosure.
It is actually a lot more powerful than a cerbo, fastest CPU in the range.
