Hello
I have a MultiPlus-II 12/3000/12-50 120V (0x2705 running v556). One VE.Bus port is connected to a VE.Bus Smart dongle and the other is connected to a MK3-USB attached to a Raspberry Pi running Venus OS v3.55.
Generally, everything works fine. I can monitor the MultiPlus both via Venus OS (and on VRM) and using VictronConnect over bluetooth through the smart dongle. I normally turn the MP on/off via VictronConnect over bluetooth to the dongle and that generally works fine. Yesterday, I successfully upgraded the MP firmware via VRM, so the Venus OS to MP connection seems fine (although I ended up restoring the config manually using VE Configure on Windows through the MK3).
The issue - I am unable to turn on the MP via Venus OS (either console or via VRM). When I change the state from off to either on or inverter, the MP stays off and the status either changes to Unknown or stays Off depending on where you look. I don’t generally try to turn it off via Venus/VRM when it is already on, but I think it may sometimes work and sometimes not.
Any ideas or tips for troubleshooting? I can’t imagine this doesn’t work with eg. a Cerbo GX - so, what’s different about an MK3-USB+RasPi?
