Cannot remove stale/ghost EVCS devices from VRM-Dashboard
I run a Cerbo GX (VenusOS v3.73) with an ESS, 3 Phase Quattro-II 48/5000/70-2x50 , 2 x SmartSolar MPPT RS 450/200, PV and a ~30 kWh Pylontech battery. I integrated my openWB Series2 wallbox as an EV charger using the freakent dbus-mqtt-devices driver (v0.9.0). A Node-RED flow reads the openWB MQTT values and publishes them to the proxy. This works very well — power, current (L1), status, charged energy and session values all arrive correctly on the DBus and are displayed in VRM.
The problem: On my VRM Dashboard page there are two EVCS tiles — the active one (currently status charged, on the left side) and a second, dead one that just shows “EVCS 0 W”. I would like to remove this dead tile on the right side, connected to the ACout, it does not exist.
The dead tile is a leftover from my initial testing phase, where I registered the EV charger a few times under different names before settling on the final setup.
What I have already verified — the old device is genuinely gone, only VRM still remembers it:
  • Remote Console → Device list: only the current active device is shown. No ghosts.
  • settings.xml on the Cerbo: the old devices are not present there either.
  • dbus-spy: only one active evcharger service exists (com.victronenergy.evcharger.mqtt_openWB_oWB), reporting live values.
    dbus-spy:
The only place the old devices still appear is under VRM → Advanced (widget/graph configuration), where two old EV chargers are listed as “last seen 3 months ago” — which seems to be why the dead tile persists on the dashboard.
I have already searched the community and tried the usual approaches, but there is no option to delete these stale sub-devices, and the normal “remove device” path does not apply (they are not in the device list).
My question: How can I permanently remove this stale EVCS entry so the dead tile disappears from my VRM Dashboard and only the active device remains? Is this something that can only be cleared server-side by Victron?
Thanks in advance for any help.
For most devices when you open the device list in VRM and push the plus button on the right. There appears the remove device option.
like mentioned above i don`t have these ghost devices in my device list, so i can’t delete them.
But thank you for your answer.
regards
Ahh. Sorry that I didn’t read correctly that you don’t have them in your device list. I do have the same issue with a virtual EV charging station. So I guess it would be a bug in the VenusOS software. I’m on beta 3.80~27, so the problem isn’t fixed there.
