Can we replace charger+inverter with multiplus?
I am planning to setup the inverter and the charger (for refresh battery) in a truck. I wonder if we can combine the charger and the inverter by using the multiplus instead. Since we don’t have the secondary battery, what should be the best way to join the DC output of the multiplus to the car electrical system? If I understand correctly both inverter and charger can connect directly to the car electrical system, but multiplus cannot.
I see what you are trying to do here and it makes sense. I just don’t think this is a good idea. Starter batteries aren’t meant for larger sustained loads. They are not “deep cycle” in the sense that you will drastically reduce the lifespan of the battery by regularly deeply discharging it. Also, you definitely run the risk of stranding yourself. The most you would want to do is use an inverter for very small and intermittent loads.
There may also be issues with the demand put on the alternator if the multiplus is being used while the engine is running. The alternator may not be designed to keep up with the kind of loads the Multiplus is capable of supporting.
If you want to have an inverter and a charger for your starting battery consider a small Multiplus(they come as small as 500VA) and a small LiFePO4 battery(100Ah). Then connect the Multiplus trickle charger to the starting battery. This is the type of use the Multiplus was designed for.
