Greetings!
I have a 2025 Ford Transit with dual starting batteries from the factory. I need to install a wheelchair lift in it for my son, 120VAC outlets for misc lower power things during trips, and we were thinking about installing a 12V fan or AC in the future (could do 120VAC if needed) for camping. I don’t want to turn this into a full camper setup with house batteries and was thinking I could do it with the factory starting batteries with limitations; basically always connect shore power when any load is required. The inverter would only work when the engine is on based on my plan. Well, after I already purchased the multiplus 12V/800VA, i noticed this statement in the manual:
“This product is not suitable for direct connection to a vehicle’s electrical system. It should be connected to a dedicated DC system that includes a dedicated service or house battery, appropriate fusing, and the appropriate gauge of DC wiring.”
I guess I should read first but it was advertised as an inverter and charger so I figured why wouldn’t it work, right? In hindsight, I should have just ordered an inverter and planned to install a switch for 120VAC power with no extra 12VDC loads. Without 12VDC loads while the engine is off, the multiplus is overkill. At this point I can either try to sell this one for a loss and downgrade to an inverter or hope that this one works OK. Does anyone know what the drawbacks are of installing this based on my wiring? The DC voltage range is well within the alternator’s range so the specs on face value appear like it’ll inverter the DC just fine. Maybe using the charging circuit to charge the starting batteries at full amps while connected to the car may be an issue instead of just a trickle charge?
