Hello There. I know, this isn’t exactly a VE topic, however i hope the knowledge is somewhere here to be found ![]()
Here’s the plan: We have two Supervolt SX100-SE (*) for our caravan. I recently found out, that you can connect them to the VE Cerbo GX. I also found out, that that is basically just a small computer running VE’s Venus OS. Therefore, i figured, it should be possible to talk with the Batteries using a Raspberry Pi (maybe also get a measuring shunt for solar input or something in the future).
However, i am a bit lost on how one would connect the two. I found a Guide in the Venus OS Github wiki, and going from there and with some googeling i came to the USB2CAN from Innomaker which is somewhat less price intensive that the industrial alternatives. Whichever one you choose, all of them seem to have that 9 pin D-SUB connector. The Supervolt Batteries only have RJ45 Ports, like the Cerbo GX (afaik). Additionally, there is this original VE.Can to Supervolt CAN-Bus Cable for relatively cheap, however there is no pinout available for me to know how to possibly rewire that to the D-SUB connector.
If anyone here has some knowledge with the different CAN-Bus hardware and plugs, any help would be much appreciated!
Since i am new here i am only allowed to use two links and had to remove the rest, if you need any further information on any of the parts mentioned above, let me know ![]()
kind regards,
Pablo
