Can a MPPT 150/45 be used as a 48VOLT power supply?
My customer have 57volt supply (3amps) and needs to step down to 48volts.
No its better to use an orion TR 48/48 dc converter for that
My customer needs today. We only have the MPPT150/45 in stock. Wood it work? Can it be set for 48 volts as a power supply?
Its a charger not a power supply, you can try but you will have to figure out settings… worst case you will brake it
https://www.victronenergy.com/live/drafts:mppt_faq#q4can_the_output_of_the_mppt_be_used_as_a_power_supply_thus_without_batteries
The answer is yes it can under certain circumstances.
