Hello everyone — I’ve already tried searching, but unfortunately couldn’t find any relevant posts.
This is about our Campster, which has the following setup:
120 W solar panel on the roof
1x BlueSolar PWM-DUO (SCC010020060)
1x Electronicx LiFePo4, 100 Ah
1x SmartShunt 500A
The setup basically works, but I have noticed that a few things probably weren’t configured correctly. Among other things, b01 (i.e. lead-acid) was apparently selected on the DUO — charging worked up to around 13.3 V, of course…
I’ve now set the DUO to b04 (LiFePo4). The unit then restarted, but unfortunately it’s now complaining that the (non-existent) second battery has a rather low voltage of 0.2 V.
I’ve configured the following parameters on the SmartShunt via the app:
Capacity: 100 Ah
Charged voltage: 14.0 V (I understood this to mean that the Duo only charges to 14.2 V, so I should subtract 0.2 V)
Discharge floor: 20%
Tail current: 4%
Peukert: 1.05
Charge efficiency: 99%
The shunt is now showing 100% SoC (which can’t be right at 13.3 V).
So, here are my questions for you:
How can I get the DUO to forget about the second battery? The error message keeps flashing.
Do the SmartShunt settings look sensible and correct?
How do I reset the SmartShunt so that it shows the correct state of charge?
Does the temperature sensor on the DUO have any effect with LiFePo4, or should I disconnect it?
Thanks very much for any help, and please feel free to ask any follow-up questions.
Try fully disconnecting both the battery and PV. Let it sit for 30 min. Then reconnect starting with the battery first. The controller needs to auto detect the battery before solar is connected. You don’t need any temperature compensation with LiFePO4 batteries and when you set the controller to LiFePO4 it should disable this.
On another note, this is a great opportunity to do an easy upgrade to a SmartSolar MPPT; very low hanging fruit for a significant increase in charging and usability.
Take the PWM solar charge controller for the Li batteries out of service and switch to MPPT!!
This will destroy your Li battery in the long run (usually, the panel voltage is pulsed through to the batteries!! That means if you have a panel voltage of 20V+, it gets applied directly to the 12V battery)
Hi @DirkW, yes, it’s a Pössl Campster. The Schaudt unit is fitted, but it’s wired up separately (I didn’t do it myself). I’ll keep the second output in mind for the starter battery, which can sometimes be a bit problematic in the SpaceTourer (and its Stellantis siblings); so far, I’ve been lucky.
Hi @Karl-Heinz, I’ll be happy to have a look and work out the numbers. How complex is the conversion? I’m only at DIY-store level when it comes to practical stuff . I’d be happy to have a go at battery-related things too.
Hi @DirkW — I’ll answer both questions in one reply
Yes, I replaced the original battery — only one really fits in the Campster (which means the van fits in the garage ).
The whole setup is connected to the battery, just as before. That includes the lighting, the auxiliary heater and the kitchen unit (2 gas burners and a tap). There are also two 12 V sockets (the cigarette-lighter type) that are permanently powered, so they work even when the setup is switched off. I usually plug a small Jackery in there so I can run my laptop on 230 V — the Jackery then charges at about 80 W, and the laptop can draw more power when needed.
I also like using the Campster as a mobile office, and the load can add up. Sometimes I use my trusty old Lenovo P52 — that can draw as much as 170 W …
The controller isn’t the original one; I had my trusted dealer install it (as far as I know, there isn’t one available from the factory).
Does the Campster have a battery-to-battery charger?
Because the lithium battery takes ALL the current it can get, which means it can overload the wiring and alternator.
Jackery = power station?
Cigarette lighter plugs are NEVER suitable for the currents they’re rated for. The ones from Pro-Car get hot quickly too…
I’ve set it to Lithium and also set it to 100% on battery 1. The PV is charging correctly too (I took the photo in the garage).
I also had a look at the charging booster, and it was indeed set incorrectly! In the Campster, there’s an electrical control unit at the front under the driver’s seat, which controls the shore power, and the booster is behind a cover under the driver’s seat at the back. My trusted dealer apparently didn’t know that…
The shunt isn’t fully wired up either, so the two permanently powered sockets aren’t being monitored…
That needs to be put right.
Thanks very much for all your advice. Do you perhaps know a professional in the Black Forest who knows their way around this?
This should show the logical wiring in my Campster. I’m still going to disconnect or disable the temperature sensors, test the auxiliary heater (to see whether it runs through the shunt) and get the double socket wired up properly.
I hardly ever use shore power, because the battery is usually more than enough — it would only be useful for the starter battery. The van is in use all year round, though, so it’s never left standing for long.
Once that’s done, I’ll let you know — I may also switch to SmartSolar:
