Calypso Ultrasonic
Hi everyone,
I am planning to connect a Calypso Ultrasonic anemometer to my Victron Cerbo GX using Signal K, and I am looking for advice on the best way to set this up.
My ultimate goal is to have the wind data (Wind Speed and Direction) visible as a widget on the VRM mobile app and portal dashboard.
I understand that I need to switch my Cerbo GX over to the “Venus OS Large” firmware to get built-in support for Signal K and Node-RED. However, I want to make sure the data flows all the way from the sensor to VRM.
Could anyone with a similar setup guide me on the following:
  1. Sensor to Signal K: Does the internal Bluetooth stack on the Cerbo GX reliably handle the wireless connection if I use the Bluetooth version of the Calypso (using the signalk-calypso-ultrasonic plugin), or is it highly recommended to use the wired NMEA 2000 (ULP) version through a gateway instead?
  2. Signal K to Venus OS DBus: What is currently the most stable way to inject the Signal K wind data paths into the Venus OS DBus system so that it registers as a legitimate weather/wind station device
Any tips, node examples, or plugin recommendations to get this working smoothly would be greatly appreciated
Best Regards Kjelli.
