While you’re there is any chance we can get the granularity of this (and the min/max settings) increased to 2 or 3 (2 would work, 3 would be better) decimal places instead of one?
Right now I have to use dbus-spy to setup my sensors and it feels like it should be something in the UI.
Yes, that was on the list already as well. 3 decimals seems a bit excessive though. Without double checking I’d think that that is at least well beyond the capabilities of that hardware.
Its a 12bit adc, is max 4092 steps from 0 to 10V; probably a bit less.
Using dbus-spy I can see the resolution goes down to 3 decimal points.
To get accurate resolution on mine I need to go to 3 decimal places. It reads the third point in .005v steps.
What would actually be even cooler would be a “sync” button on the min/max pages when you go to edit the value, that just sets it to the current read value. Then you don’t even need to think about what the value is, it just grabs the current read and sets it.
0 - 4v at maximum tank height (1 metre) but on a smaller tank it’s less. On my tank the range is 0.6v
The GX Tabk reads in .005 volt steps. It would be nice to be able to configure in those steps, or simply a button that says “set min” or “set max” which reads the current value to 3 decimal places and sets the min/max.
I’ve had to use dbus-spy to get mine configured correctly.
Hi @zindello , per yesterday we have v3.60~8 in beta, which changes the min/max settable precision to 0.005V steps; please let me know if all works well for you there - have a good weekend.
