I am seeing a reproducible New UI display-update issue on a Cerbo S GX running official Venus OS v3.81.
Setup
Cerbo S GX
Venus OS v3.81 official release
New UI / GUI v2
Victron ET112 energy meter
ET112 used to monitor the AC consumption/output of a non-Victron inverter
Behaviour
The ET112 power reading updates normally while the Cerbo display is active.
Approximately 10 seconds after the last touch input, the Cerbo UI appears to enter its idle/low-power display state. At that point, the numerical power value in watts stops updating and remains frozen at whatever value was displayed immediately before the idle transition.
The underlying ET112 measurement is still updating. The graph associated with the same value continues to update correctly while the numerical watt value remains frozen.
Touching the screen again causes the numerical watt value to resume updating.
Expected behaviour
Entering the display idle/low-power state should not stop the numerical ET112 watt value from updating.
Steps to reproduce
Display the ET112 power value in the New UI.
Change the inverter load and confirm that the watt value updates normally.
Stop touching the screen.
Wait approximately 10 seconds for the Cerbo UI to enter its idle/low-power state.
Change the inverter load.
The graph continues to show the changing load, but the numerical watt value remains frozen.
Touch the screen and the numerical value begins updating again.
This appears potentially related to the earlier gui-v2 display-blanking refresh issue that was reported as fixed in v3.72, but the behaviour is still reproducible on official v3.81.
