Hi
possible to bring the Smart Shunt to Lan/Wifi to show up in VRM or Connect on Handy?
Thx
Hi
Thx
Yes it has Bluetooth, you can connect with the victron app and see it on your phone.
In order for it to show up in VRM you would need to use some sort of GX device, as the interface to VRM, but then you would also need to use VE.direct instead. You could then also connect via Remote VictronConnect from your phone.
If you just want to read out the Shunts values for example over MQTT, you could use an ESPhome bridge like
do not want just the data, VRM is the choice.
seams only to have one sollution, the Global Link 520. ?
Could use a rasberry pi if you dont want to go gx route. Pi would be cheaper than 520
raspi with venus os. it need to connect autom. every time it gets into wlan area. does it safe all data from the shunt and sends it later on connected to the web to VRM?
I would say a pi could be configured for that with the correct programming.
Pi is a small computer and as we know a computer is a wonderful thing, so great they are taking over.
