BSLBATT batteries unresponsive after failed firmware update – unresolved warranty case
I have a victron system with 3 bslbatt batteries 45 kWh. My local victron installer installed the batteries in march. I noticed right away problems with SOC and batteries that are going offline, even at night. And huge cel imbalance
The company who installed the batteries kept saying, everything is fine. There is no problem
I didn’t believe this so I had to hire another company to connect a laptop to the batteries and to get all the data. With this data I went to bslbatt support because my local company didn’t want to help me.
4 months later bslbatt support finally said the batteries need a firmware update. Bslbatt did this firmware remote but failed. They said we can not do this when the batteries are discharging. But they did do the update when the batteries were discharging. Power went out in the middle of the night. The next day I asked the other company to check and the result, 2 batteries are bricked.
there is simply no communication with the bms.
The upper computer does not connect. I tried your bms updated program, it does not connect. The button on the battery is not responsive and won’t turn of the battery. It is simply bricket stuck and unresponsive.
So I asked for new batteries replacement under warranty. Bslbatt said they will handle this with my installer. But they said the BMS need to be replaced. You don’t get new batteries.
I don’t trust my local installer to replace the BMS. They don’t have the knowledge. BMS replacement is a big risk when the installer doesn’t have the knowledge?
Any advice what I should do?
Thanks!
Yes, contact problems can lead to overheating and cell damage, or even fires.
The initialisation phase probably wasn’t carried out properly (some manufacturers require special charging steps at the start, with reduced voltage and/or limited current).
Hi Chris, sorry to hear you are having a poor experience with your installer and the batteries.
With respect, this is a matter between you and the distributor, installer and BSL, it is not a Victron issue and is well beyond the scope of this forum.
Our community guidelines ask that these matters be kept between the involved parties and not become a topic of discussion here.
You are welcome to search for topics related to that brand on the forum and archive, there have been a few over the years.
If you have lost faith in an installer, then ask the distributor they used to recommend another, or search the where to buy page for suitable alternatives.
A BMS replacement is actually fairly simple.
Good safe practices and VDE rated tools because sparks with no protection is bad.
For the BSL it will be - unscrew unplug replug screw back together. Make sure stuff is right but not over tightened.
No messing with cells or balance leads etc. and you can’t really even get the pugs wrong. Unless you are ham fisted.. and ham brained.
I have replaced a few BMS’s in my time and can tell you a logical person with a bit of care can do it.
A few you tube videos are available
But yeah here we don’t air dirty laundry so to speak. But you are welcome to ask for help otherwise
So be careful when replacing the BMS!
Use insulated tools (a Russian YouTuber uses heat-shrink tubing to make makeshift insulation for his tools during installation)!
Also use insulating mats around the work area, if necessary, to prevent short circuits.
Wear suitable personal protective equipment (flame-retardant gloves/clothing, safety glasses).
Have fun!
Ha ha and don’t drop the screws
Or a washer, we have a whole topic on that subject :sweat_smile:
