I wonder if I can keep the Blue Smart Charger 12V 5A always in charging mode.
At the moment I always switch of the 230V supply.
My concern is that there is something like a short circuit or at least an inefficiency in a circle:
- the generator loads the starter battery and (via the Orion XS battery booster) the lithium battery
- The lithium battery also powers the starter battery (via the BSC12/5 and the multiplus)
Is the BSC12/5 clever enough to stop charging the starter battery when it’s voltage is high due to the active generator?
How do you manage your charger?
