BMV700 showing fully chaged too soon
My BMV700 often shows 100% charged when I had expected it to take longer to charge. Its installed on a boat, and for example we can discharge the 360AH bank by 100AH then perhaps charge at 50amps. So I would expect 2 hours till fully charged (assuming constant current) but it often indicates 100% after about 1 hour. Is there a setting on the BMV700 that I should check, I am fairly sure I have the capacity set to 360AH but will check.
It is often related to the two items mentioned in the manual
See this FAQ
@Angus_S which battery is being used?
Lead-acid, LFP?
Is the BMV configured using a dongle or manually on the BMV? The latter can sometimes go wrong.
Manually on the BMV
Well, that’s usually not very easy, and as I already mentioned, it does go wrong quite often.
Perhaps someone can help you get a dongle; then you can easily read out how it’s configured.
What type of battery?
Its lead acid 3x 120Ah
Could you indicate what the charged voltage is set to, the tail current and the charged detection time?
Soor for the delay in responding, I have had a look now. Tail Current 4%. Charged Voltage 13.2V. Charged detection time 03.
13.2V is too low, set it 0.2V below the absorption voltage in your chargers. The FAQ I linked to above describes why this is too low.
Many thanks, we have 3 charging methods, a mains powered charger, the engine alternator and solar panels (but not doing much in Scotland today:-)). I will try a higher voltage. The engine alternator puts in about 14.4 when the batteries are low.
You need to know how a lead-acid battery should be charged and how to tell when it is full. It is first charged at the maximum current it can accept. Once the absorption voltage is reached, the voltage is limited. Sulphuric acid forms in the plates, coating their surfaces. The acid density is then higher. But the battery voltage also rises. That is why the battery is charged at 14.4 V. The current then slowly decreases over several hours. When the battery is almost full, only a very small amount of sulphuric acid forms in the plates. The acid density at the plate surfaces decreases, and so does the battery voltage. From this point on, a substantial proportion of the current can no longer be used for charging. Instead, the electrolyte is now decomposed into hydrogen and oxygen. That is why the voltage must be lowered to the float voltage, especially with VRLA batteries. However, the battery is not yet full. It takes several more hours for the current to drop to about 1% of the Ah rating. The battery is fully charged when the charging current does not change for hours.
The battery monitor must therefore be configured for the values that apply at this point:
So the voltage must reach a value below the float voltage, and the current must be only 2% of the Ah rating. A healthy, unsulphated battery would draw a higher current at that voltage! Contrary to what many people think, the monitor is not synchronised! But there is another important setting: what happens if the charger is switched off shortly after the float phase is reached, or a cloud passes over a PV panel? The current drops immediately and can fall below 2% of the Ah rating. But the voltage drops much more slowly. For a short time, this produces the values for a full battery, and the battery monitor would synchronise to 100%. This is prevented during the “charged detection Time”. After this time has elapsed, the voltage should have dropped below the “charged Voltage” if the battery is not full. Here is an example of a well-functioning setting for Gel batteries with correctly configured charge controllers.
Different values must be configured for flooded batteries and LiFePO4!
So the cause is usually incorrect settings. But a sulphated battery would also produce the values for “Full” too early.
I had exactly the same issue on a boat charging from alternators. The default tail current, Tc, is too high. At 4% once the charging current drops below 4% of 360Ah, 14.4A, the BMV SOC will jump to 100%. If you connect the BMV to a PC and record using the BMV software with a short interval, you’ll see a sudden jump of SOC from say 90% to 100%.
Reduce Tc to the minimum and it should then be OK.
