BMV700 Bluetooth dongle data readout
Dear all,
I can fetch the BMV bluetooth dongle data and it looks like this:
02E1100203020000000066E94BD4EF0C2C3B884CFA59CA342B2E0C
The relevant information would be
Where do I find the documentation of the data structure?
Looks like this information is not in this documentation: https://communityarchive.victronenergy.com/storage/attachments/extra-manufacturer-data-2022-12-14.pdf
Can someone help on this?
Best
Sascha
@lxonline
Ia there something you know about?
I don’t know of any specific documentation officially available.
Playing with Hexa has not been a persuit of mine. (It is on my list)
I followed your last thread where you chatted with thiemo though.
Is fabians code not helping?
You may have to reverse engineer it (compare it to data you see in the VC app and work backwards.
Chat Gpt?
Hi @lxonline
That’s a bit the problem with the data.
The encrypted data are 02E110020302000000000000000000860000000000000000000000000000000C
The code is doing decryption I’m wondering how this is working to get the decrypted values
If not providing the key.
Anyway the values are fetched but make no sense :confused:
With all my other devices wit ble integrated this is working well but not the one with the BT dongle…
Tried also chat gpt but see the data above…
Interesting how the data is different from from the BT dongle in hex.
I know it is different how it interacts in the VE smart network.
@thiemovanengelen
can you add something here - last time your answer was awesome.
Hi @Saschakopp
There is something wrong with this encrypted data. Is the instant readout data visible and showing sane values in VictronConnect on a phone / MacBook?
If it looks normal there, then there is a problem with the data reception on your end.
Kind regards,
Thiemo van Engelen
@Saschakopp I have been working on the same challenge for a few weeks now. The information is scattered everywhere and really needs to be centalised. The most useful info comes from the original post by Victron staffer Matthijs on the old Victron forum archive “Victron Bluetooth Advertising Protocol” .
That post is the source of the “Extra Manufacturer Data” PDF you linked in your first post. But much further down are very useful contributions by Jake Baldwin (19 May 23) and Chris Jackson (3 Nov 23).
For my convenience (and now yours :slight_smile: I captured those contributions into this text document:
Victron protocol - Jake Baldwin 19 May 2023 (B).pdf (46.8 KB)
That info will give you lot’s of help on how to decode the data.
I highly recommend the 'nRF Connect" Bluetooth sniffer app. I’ve been using it on my Android mobile to look at the advertised data from my Smartshunt, BMV-712 battery monitors, and my MPPT100/30 solar charger.
For example this is an example of the RAW data from my Smartshunt:
0x0201061AFFE102100289A3025D9795F874601C3F869B6A196258EB22EDD314094241545462616E6B20536D6172745368756E74
Decoding this in 3 parts
1:020106
2:1AFFE102100289A3025D9795F874601C3F869B6A196258EB22EDD3
3:14094241545462616E6B20536D6172745368756E74
part 1
02 len: 2 bytes
01 type: 1 (flags)
06 value: 6 binary:0000 0110
part 2
1A len : 0x1A (26) bytes
FF type: 0xFF (the following 25 bytes are Vendor specific)
E102 Company identifier 0x02E1 (little endian) = “Victron Energy BV” (see Bluetooth Assigned Numbers p.234)
10 Manufacturer Data Record Type (always (0x10)
0289 Model Id for Smartshunt Battery Monitor
A3 “read out type” not always 0xA3 (JB ref A shows 0xA0)
02 Record Type: 0x02 = Battery Monitor (ref B)
the data above remains constant, whereas
the data below (except 0x95 constant) is updated continually
So these are only example data:
5D97 Nonce/Counter, the “salt” used in decryption (little endian)
95 Constant, so far (JB says this should match first byte of Encryption Key for this device but that’s 0x55 in m case??)
F874601C3F869B6A196258EB22EDD314 Encyrpted data (15 bytes)
(the “Battery Monitor” table in “Extra Manufacturing Data” doc confirms this should be 15 bytes, and shows how the bytes are allocated. I think this is what you were looking for in this thread.)
part 3
14 len : 0x14 (20 bytes)
09 type: 0x09 Complete Local name (from BT Assigned Numbers doc, table 2.3 Common Data Types)
42 41 54 54 62 61 6E 6B 20 53 6D 61 72 74 53 68 75 6E 74 (19 characters ASCII)
ASCII for “BATTbank_Smartshunt”
