Hi. I’ve just seen a diagram where the small red wire (‘‘power cable’’) that’s connected to the B1 terminal of the smart shunt goes directly to the Lynx Distributor positive bar instead of going to the battery/battery bank positive terminal.
I suppose it’s ok considering this is NOT a temperature sensor destined to be connected to the batteries but a simple cable reading the charge voltage ?
Just to confirm; I like to keep things tight and since my shunt is connected directly to the Lynx, that’s be a simple connection to do instead of running to the batts.
For an accurate reading the wire should be connected as close as possible to the battery (same for the negative - the shunt itself).
If the wire from the battery to the Lynx is big enough than there shouldn’t be a significant voltage drop.
