I have the Victron Smartshunt IP65 and optional BMV 702/712 temperature sensor. This sensor comes with an M10 size lug/sensor, and it seems you can’t get an M8 size lug. I have done the conversion of fitting the temperature sensor to the Smartshunt IP65.
My battery poles are M8, and I have an MRBF fuse fitted. With this setup in mind, I’d really appreciate thoughts on the following:
I assume that cutting off and replacing the M10 sensor lug with an M8 size lug is not an option since the lug incorporates the sensor. That said, what is the most effective/safest way of fitting the M10 sensor lug to the M8 MRBF setup?
I’m thinking I should place the temperature sensor lug directly after the MRBF bar (before the actual MRBF main battery fuse) and bolt it down (via the battery post bolt), or should I place it on the MRBF M8 post after the main battery cable? Either way I would need to ensure movement is kept to a minimum (this is not a mobile setup, which I guess will result in less possible movement).
Any thoughts/solutions appreciated. Cheers all.
