Black Resin Dripping from Multiplus II 48/6k5 - unit was working fine
I noticed these drips today on top of the DC Isolator. The Multiplus II 48/6k5 is located right above. At that time the unit was working fine. Inverting/charging, just the usual. Not very hot to the touch. Maybe a little more transformer hum than usually, but that could be my imagination.
There are more drips on the battery box, further below. On the battery box they are spread quite wide. Not dripped straight down. I can only assume either they were spread out by falling through the fan, or something disintegrated with some violence.
One drip is inside the cover of the connection area, confirming the drips originate inside the MPII and aren’t a spill from elsewhere:
Google AI suggests that this might have been caused by a hot spot inside the transformer, melting some of the insulation there. It strongly suggested I turn off the system immediately and ask for a warranty replacement. Ok, turn off: done.
Google AI also warned me not to open the main cover of the MPII to look for more information from which component the drips originate. Not to protect me (I know to isolate AC, DC and wait for capacitors to discharge), but because opening the cover could possibly void the warranty.
The dealer I bought the MPII from did not call back before close of business today. The electrician who installed my system is even harder to reach and very expensive to get to visit. I would very much like to get some clarity with the help of this forum.
Background to the system:
  • It was first installed 2 years ago and was running fine. 2 weeks ago the MPII 48/5000 I started out with was replaced by the MP II 48/6k5 that now seems to cause trouble.
  • Simple disconnect / reconnect. Wires were already sized big enough. No other components were changed at that time.
  • Looking inside the wiring compartment I can not see any damage (no molten connectors), other than the one drop on the actual cover in the photo.
  • I did not notice any strange smells either.
Questions to to everyone:
  1. Would these photos be enough to lodge an RMA, possibly with advance replacement from Victron? Or can there be a benign explanation for sticky black stuff dripping out from an MPII that would not be a significant fault?
  2. If there is any doubt: any reason not to open the main cover and look for more evidence for the origin of those drips? Does that really void warranty?
Maybe you can work out where it came from from the video … Removing the cover probably won’t affect the warranty …
I reckon the liquid is potting compound dripping from the toroidal core … The heat made it run off somewhere … obviously that’s not ideal, but its insulating properties should mean it won’t cause any damage … unless it sticks to the fan and blocks it :downcast_face_with_sweat:
… didn’t “Venom” start out like that too … :sweat_smile: … Be careful
Thank you @Steffen, nice video!
Knowing where the LED panel is plugged in and seeing everything else was well clear of the lid made the decision easy to take a peek under the hood.
Yep, I don’t think there’s any doubt what happened. Gemini guessed exactly right. Hot spots in the transformer winding melted the potting compound. Since I have to assume that the insulation has suffered as well the unit remains “off” until replacement. The house is back on “mains power”.
Let’s see how long that warranty process will take. Glad I didn’t get around to sell the old 48/5000 yet, it can get used again in the meantime.
