I understand a bilge pump switch can be installed to monitor and alert about a high-water level on my boat using the Cerbo GX. Sounds pretty straight forward, but does anyone have the wiring diagram for doing it? I simply want the switch to come on when water reaches a certain level and for the GX to alert me.
Thanks,
If you have a float switch which has 2 cables then this is straightforward. Choose one of the digital inputs on the Cerbo GX, connect 1 cable to the data terminal for that digital input and the other cable to the ground terminal for that digital input. When the float rises the float switch makes contact and the digital signal alarms. You will need to activate the digital input in the Cerbo GX settings.
This is how mine are wired. If you have a different type of switch then I can not help.
