Hi there everyone,
For the last few weeks we have been testing EV charging with Dynamic ESS with a small group of users. Today it opens to everyone as a beta.
The closed beta went well: nobody ended up with an uncharged car when they needed it. Thank you to all involved!
What this new feature does
Dynamic ESS now plans your EV charging. It looks at energy prices, your solar forecast and your battery, and charges your car in the cheapest hours whilst making sure its sufficiently charged at your configured departure time.
- Get a push notification when you plug the vehicle in. The push notification will ask you whether you want to override the default settings for the charge that day.
Set your target SOC and departure time. While the car is plugged in, you can change these for the current session without touching your defaults.
Change your default target SOC and departure time. In the Dynamic ESS settings.
See the plan. The Dynamic ESS graphs have a new EV charging tab.
Your car still gets charged if time runs out. If the car hasn’t reached its target SOC by departure time and is still plugged in, it keeps charging until it does.
How to start testing this
Link your EV to make it possible for Dynamic ESS to knows its actual state of charge.
Go to Preferences > Integrations > Vehicles in VRM (direct link), then:
Sign in with your car brand’s app to give VRM access
Link the car to VRM
Choose the VRM site your car belongs to
Your car then shows up under Vehicles in the Dynamic ESS configuration, where you can turn on optimal charging. For supported brands, see this earlier post.
Plugging in a car that isn’t linked to VRM, like a guest’s car? Press ‘charge now’ on the notification pop up or in the controls panel.
Alternatively, you can set up a NodeRED flow for this.
What you need
A Victron EV Charging Station, set to Auto mode
Venus OS 3.90-beta8 on your GX device
Dynamic ESS switched on
Make sure you EVCS is connected via MQTT to Venus OS
Costs when linking a car
Optimal EV charging will become a paid feature: €4 per month or €42 per year, exl. VAT, per VRM installation, regardless of the number of linked cars.
Everyone gets to try the feature for 1 month for free. If you helped us BETA test the vehicle integration before today, you receive 3 months of the feature for free as a token of our appreciation.
You need to complete the payment flow in the coming 7 days to keep access to the feature. Your trial period will be activated immediately.
Why? The subscription covers the costs that Victron makes to link to your vehicle data.
Car SOC information is required for every car that is linked. Victron retrieves that information through a third party service, which costs us money every month for every VRM installation. The subscription is only to cover those costs.
We understand this subscription is a first for Victron, and this may raise some questions. To clarify our position:
- VRM is not becoming a paid platform.
- Victron has no intent to come with subscription models to ‘monetize value’, like many companies do these days.
- Similar to our open software philosophy, we care deeply about the added value from our software coming for free with every Victron product.
You can set it up yourself, for free
If you can get your car’s state of charge into Node-RED, you can set up a virtual vehicle there and use optimal charging at no cost. Whether that’s possible depends on your car brand. If you’re comfortable with Node-RED, it’s a perfectly good choice.
Will it save you money?
If you already time your charging by hand, around sunny hours or cheap prices, this is exactly what Dynamic ESS now does for you. Automatically.
How much you save depends on your country, your energy contract and your setup. With a dynamic energy contract or a lot of solar, the savings can be well above the monthly subscription fee of €4. With a fixed energy price and little solar, there is less to gain.
And apart from the money, it saves you the hassle of figuring out the best moment to charge.
Use the free month to find out what it does for your installation.
Next up
A weekly schedule, so you can set a target for each day. Optimal vehicle charging without using Dynamic ESS for battery charges / discharges. After that, planning charges more than one day ahead.
Feedback
Please use this form. It first asks for your firmware version and settings, which helps us find the cause much faster. We respond to the form faster than to posts in this thread.
On behalf of the VRM team,
Barbara
