Beta 3.80 Shelly support
Hi everyone,
I recently updated a installation to version v3.80-42. Unfortunately, I noticed that the Shelly 3EM is still not supported and is not being recognized by the Victron system.
The Shelly also failed to work / was not recognized in versions v3.80-36 and v3.80-39. The last version where everything worked completely fine without any issues was v3.80-14.
In my setup, the Shelly is used to transmit power and energy data for a heat pump.
Has anyone else encountered this issue, or is there a known workaround / upcoming fix?
Thanks!
Subject: [SOLVED] Shelly 3EM not recognized after v3.80-42 update – Manual re-add required
Hi everyone,
A quick report and solution regarding the Shelly 3EM on recent Venus OS builds (v3.80-36, v3.80-39, and v3.80-42):
Initially, after updating from v3.80-14 (where everything worked flawlessly), my Shelly 3EM was no longer detected by the system and stopped sending power data for my heat pump.
Update / Solution:
After testing back and forth across several versions, I found the fix:
  • After updating to v3.80-42, you need to manually re-add the Shelly 3EM in the Shelly integration settings.
  • Once re-added manually, the system immediately recognized it as a heat pump, and it was reachable and working again without any issues.
If your Shelly 3EM disappears or isn’t recognized after updating to v3.80-42, simply re-add it manually in the settings!
And does DESS also take your heat pump’s power consumption into account?
Yes, after manually adding the Shelly, it is immediately recognized, gets its old assignment as a heat pump back, and everything works as before. We will have to wait and see how well DESS actually takes the heating data into account in the winter.
