I’m designing an off-grid solar power system for a maritime lighthouse (El Hierro, Canary Islands).
The site has no grid connection, but there is a diesel generator available for backup.
The proposed setup so far:
Battery bank: 24 × 2 V – 3750 Ah (lead-acid stationary), connected in series → 48 V / 180 kWh gross
PV array: 12 × 480 W panels → 5.76 kWp total
Expected loads: mainly lighting, communications, and control systems (moderate continuous power, critical uptime)
I initially considered using a Victron RS 48/6000 Smart Solar inverter, but I’d like expert opinions on whether this is the best choice — or if another configuration (for example, Quattro 48/5000 or 10000 VA, with external MPPTs) would provide better redundancy, generator integration, and long-term reliability in a harsh maritime environment.
Could you please advise on:
The optimal inverter/charger + MPPT combination for this system size (48 V, 5.76 kWp, 180 kWh batteries)?
Recommendations for redundancy — e.g., two smaller inverters in parallel vs. one larger unit?
Best practices for generator integration and automatic start/stop using Victron components?
Any specific considerations for marine or corrosive environments?
Thanks in advance for your guidance.
