I am planning to install Orion XS DC to DC converter on my Jeanneau 36i sailboat. I have a relay which makes start and service batteries in parrallel ( shunted) when aternator starts producing DC current. What is the best practice for installation? I have 2 options in my mid.
Un mount the relay and connect Orion in place of the relay
Keep the relay but interset Orion between the service battary and the existing relay.
Option 2 has the advantage of disconnecting service batts immediately after engine stops since relay which will be serially connected to Orion will disconnect the circuit. However option 1 favors for the sake of simlicity.
The relay must be disconnected in any case, otherwise there’ll be a circulating current!
All other high-current loads controlled by the relay need to be checked to see whether they should be connected differently (the XS is supposed to charge).
Thanks for the sketch! To test your options, bridge the relay’s normally open contacts together on the battery side, and don’t disconnect the control connection yet. If there’s a control fuse, just pull it or switch it off.
P.S. Is the relay fused, or are the cables also wired exactly as shown in the sketch?
Fuse the Orion XS according to the manual. You could remove the relay completely in the end, but if it might be needed at sea for an emergency start or something similar, I’d just disable or bypass it and keep it on board.
I have not purchased Orion yet, in project phase yet Orion manuel says that only when start battery voltage drops a certain treshold, then servise and start batteries are seperated but this will couse some charging capacity of my start battery to flow the servise side after engine stops. However I have D+ signal from alternator which drives the relay. If I keep the relay I think that while I can use current limiting and chage management of Orion I will still be able to seperate the batteries as soon as engine stops? What do you think?
