Lead-acid battery voltage dropping on MPPT 75/15
What do you make of the voltage readings from this 45 Ah lead-acid battery connected to a 210 W PV panel and a Smartsolar MPPT 75/15? The load is a small 12 V, 5 A irrigation pump that is switched on by a solenoid valve.
It looks as though it refuses to charge,
Good afternoon,
Aaaah, a field irrigator, cool, we do not see these very often.
It looks to me it charges just fine, of course pending the sun day by day.
Can you make your question more detailed please, what is the issue, is it not pumping enough water day by day or something?
Regards, Jeroen.
Battery is charging up to +/-14.5 volts.
It started off at an unhealthy voltage. On 2nd October.
Skipped a day of charging on 4th - not healthy for the battery either.
Zero time in bulk but battery voltage rising could mean another charge source was used. Or the battery is not healthy.
Absorption time is too short.
Hi Jeroen,
Thanks for you answer and interest. It’s not a field I’m irrigating but a small greenhouse with drip system. A solenoid valve is triggered by a programmer Rainbird ESP 9V. The pump’s pressure sensor triggers the pump and all that part runs ok. The greenhouse receives the required amount of water. I sat up that system with a solar panel and the MPPP Smartsolar last week. I was tired to bring back home the battery every day for charging. I’m aware that kind of lead not AGM or Gel car battery is far from optimum for a solar system. I initially used it for 4 month plugging directly the battery to the pump. What hassles m is from day to day the min battery voltage is decreasing from 12,79 V on 3/10 to 12,36V this morning. I do not find an explanation on why it was as low as 10,87V the fisrt day I plugged it on the MPPT. I plugged first the battery, then, the solar panel, then the pump, all protected with fuses. Normally a leas battery under 11,8 or even 12 V is dead. I was wondering if something was wrong in my setup and if that situation may damage the MPPT. Cables are 4 mm2 and all the setup is indoor in a dry place. Regards
On average you are using more power every day than is being consumed if you compare the yield and consumption figures, but I accept that these are rounded to 10W. But a declining voltage before charging starts is a usual sign of this. Northern hemisphere will now see rapidly declining solar yield as the days get shorter at the quickest rate late September to early October.
Hi, thanks for your reply. I think this battery is shot. Except for today, it’s been sunny every other day. Here’s a hypothesis I’m trying to confirm: 1. The battery is “tricking” the regulator (causing it to switch to Float mode prematurely)
Following the deep discharge on October 2 (10.87 V), the lead plates oxidized and the battery’s internal resistance increased significantly.
Direct consequence in the log: as soon as the sun shines, the battery voltage rises artificially to 14.50 V within a few minutes. The regulator interprets this rapid rise as a fully charged battery:
The absorption phase lasts only 1 to 4 minutes.
The regulator immediately switches to float mode for 500 to 570 minutes per day (more than 8 hours).
In float mode, the regulator intentionally reduces the current to prevent overcharging the battery. Since the battery refuses to absorb energy, the regulator limits the solar panel’s output, which then supplies only the bare minimum.
2. The solar panel produces only what is consumed
A 210 W panel does not continuously generate 210 W: it produces only the power demanded by the system. Since the battery no longer accepts deep charging and the irrigation pump does not run continuously, the maximum power recorded peaks between 44 W and 50 W (nominal 12 V × 5 A = 60 W).
3. On October 4, production dropped to 0 Wh with a PV voltage of 0.01 V because the panel was physically disconnected that day.
So, the battery is probably shot—can I keep using it without risking damage to my Smartsolar?
What are your settings?
You could try to set a long absorption time (fixed at 5 or 8 hours) to hold it up at a higher voltage for longer. But I doubt it will help if the damage has been done.
Yes. The issue is mainly there is no surge ability of the battery to start your pump though.
Rebulk offset is also based on float voltage. So check that setting as well.
Good evening,
Sorry, busy with my own test site today.
Yes, seen also the above responses and the more detailed info, we must conclude that maybe that battery isn’t up to the task (anymore), it’s better to buy a lithium one, which is better controlled by it’s BMS, downfall is the starting current for this pump.
Can you send the specs of that pump you have, photo?
Regards, Jeroen.
Good evening,
The pump specs: PULFLEX SERIES 1042 ELECTRIC PUMP MAX FLOW RATE 3.8L/MIN - MAX PRESSURE 2.8 BAR VOLTAGE 12V
I still need to put the pump in an inspection chamber built on concrete blocks, a bit neater than this rather shoddy setup.
I’ll probably need to buy another battery, one that’s better suited to the job, but nothing too extravagant. Apart from adding a 5–7W LED that’ll run for 10 minutes once a week, I don’t have any other potential power consumers apart from this pump. It does the job perfectly well; my drip irrigation system works ideally at between 1 and 2 bars of pressure, and its flow rate is well suited to the number of drippers in the greenhouse.
Thanks
Good evening,
The site of the factory doesn’t give us any details about the pumping curve.
So, we stay with the conclusion that you maybe use the battery longer than the battery can handle…
Regards, Jeroen.
The battery no longer charges at all, so it’s dead. I’m going to replace it. Would this model be suitable for my use in a garden shed and my power consumption: Victron Super Cycle 60 Ah AGM battery?
Kind regards, Thierry
Thierry, the guys are giving you good advice. You need to replace the battery with much more capacity, likely at least 100Ah or maybe 200Ah.
AGM batteries have a discharge curve based on a slow 20h discharge (eg 100Ah over 20h is 5A), and minimum state of charge of 50% (about 12.2V) for it to be rechargeable regularly. Then there’s a temperature derating - less capacity when they are cold. In a perfect world, that means you could run your pump continuously for at most about 8h with 100Ah. I’m not taking into account the startup surge, and I don’t know how long the pump runs.
Hi Buzzy.
Thanks for your advice. I still think 100 Ah is a lot for a pump that will run for a maximum of one hour a day, in 10-minute sessions spaced about half an hour apart, and only from June to September. Outside that period, demand is likely to be quite limited. Watering is a bit like the weather: when the sun shines, we water a lot; when it goes behind the clouds, we cut back; and when it’s cold, we stop altogether.
Kind regards,
Thierry
I do not know what ambient temperature your battery will see, but for the super cycle it would be best to have temperature compensation active to limit absorption voltage when temperatures are high (Smart Battery Sense)/if your MPPT is Bluetooth enabled otherwise charge it at the bottom of the recommended voltage range.
I live in Brittany, but our temperate oceanic climate (like in the UK) is starting to become a thing of the past. So in certain situations, like the summer of 2026, temperatures can easily exceed 35°C, which isn’t great for a battery. But aside from the settings you suggest, I don’t have many ways to keep things cool… Thanks everyone for your advice.
Temperature compensation changes the voltage the battery charges to dependent on the temperature. It’s a pretty important one to have set for lead acid.
