I have multiple batterybanks of which 2 have there own cerbo gx. One is a 12V system and the other a 24V system. The systems have the following devices: 12 V electronics system
- Cerbo GX
- SmartShunt
- Phoenix Smart IP43 12/30 charger
- Orion XS 12/12-50
24 V service system
- Cerbo GX mk2
- Lynx Shunt ve.can
- MultiPlus-II 24/5000
- MPPT
- Orion XS 1400
- tank inputs
Both of the Cerbo are connected through ethernet with a Raymarine MFD as well as via Nmea2000.
In the boat I am using a victron touch to read the data, on the helm I use Raymarine to get the data. The data on raymarine works as I want it, I see both banks, dc loads/usage is correct, I can see chargers and what they are doing. And I can see my tank inputs fine. The issue is with the Cerbo TOuch ui. For some reason it is combining the data from both banks giving incorrect DC loads readings and devices that are not there. The MPPT is for example visible on the 12V system. If I disconnect physically/or disable Nmea200-out than each of the cerbo is working as intended. I tried altering device ID and ve.can Instances but that didn’t solve anything (I could change it only for the devices not for the Cerbo itself for some reason). What would be the proper way to set this up?
