Autogen start
i have a complete victron setup. i use the cerbo gx to monitor my solar, inverter charger, orion etc.
i installed an autogen start on my setup. i used this relay box from andrew at faithful journey rv
it works great. i can manually turn it on and off using vrm. i can also use any of the autostart features to start and stop etc. i happen to use soc.
that said, the hour meter doesnt work on vrm. the history shows no usage. i would really like to have it show the usage and run hours. the relay box is connect to the cerbogx on relay one like normal.
what do i need to do to get the run hours stuff to work?
thanks
tom
