Appendices missing in EasySolar-II GX 4k5 manual
The manual of the EasySolar-II GX 4k5 contains the appendices E through G. Unfortunately, the manual also references appendix A and appendix B.
  1. Am I missing something obvious about where to find these appendices?
  2. I would like to reference appendix B (specifically relay H). Is that the only relay to ground in the wiring diagram of the 4k5 datasheet?
Merci!
Do you mean the printed manual?
The HTML and PDF manuals have appendix A and B.
Often on the printed manual has all the appendicies at the back not next to the language being used.
@M_Lange you linked the MultiPlus page not that of the EasySolar. I am aware that the MultiPlus is part of the EasySolar. Even in the MultiPlus manual the ‘relay H’ is not marked in the schematic.
Also, the HTML manual of the EasySolar doesn’t list those appendices.
So, I’m not just missing something obvious, but the manual links to appendices that don’t exist and components that aren’t labeled? Does Victron usually care about correcting these things? If so, where to report these issues?
Ah ok, I rarely use the EasySolar manual because it’s basically a MultiPlus with GX and MPPT in one case.
The manual of the “old” EasySolar 3kVA and 5kVA has appendix A-G.
The ground relay is an internal relay that connects N and PE in off-grid mode.
I will escalate that to the documentation team to take a look at it.
Its the only thing that makes sense, but including the appendices and labling the relay (or removing the explicit letter in the reference) would be helpful. :folded_hands:t2:
