Also allow hostnames instead of ip for external devices
When adding devices like shelly or pv inverters an ip has to be specified but it’s not possible to use a hostname.
This causes the need of fixed ip addresses.
Normally with advanced users this is not a problem but with non technical users this can cause connectivity issues when they change there internet modem when they switch internet provider.
Using mdns names would solve this issue. The device get new ips in a new range and will be found by mdns.
I thought the Cerbo already uses mDNS to detect and store devices out of the box.
I’m specifically thinking about Shelly’s and VM-3 meters.
If a device isn’t already discoverable by the Cerbo via mDNS, I don’t think the Cerbo could resolve a manually specified mDNS host name (by way of how mDNS works).
Though maybe PV inverters don’t broadcast themselves in a way the Cerbo automatically detects? Just trying to understand the nuance here :slight_smile:
Maybe pv inverter is a bad example but shelly’s do send mdns but I they didn’t auto discover at my site
