It’s best to control the charging station via Modbus from the GX (Node-RED). It does take some time and technical know-how.
First, try adjusting the charging station settings using the Alfen ACE software. Then write the correct Modbus registers from the GX to the charging station.
I have indeed now indicated via the ACE installer that we’re using an energy management system. The charging station is then the Slave and the Cerbo GX the Master. This seems to be working well. I’m now running into another problem, but that’s definitely outside Victron’s scope. Once that problem has been resolved, I’ll report back here on how I continue investigating.
