Power supply for the camp
For a caving camp in Madagascar (2025 setup):
  • One 30 Wp solar panel
  • BlueSolar PWM-LCD&USB 12/24-5 charge controller.
  • Victron SuperPack LiFePO4 12 V/60 Ah battery.
  • 12/250 inverter.
  • Wooden box for easy connection and disconnection. On the box, a dual cigarette-lighter socket: a standard socket on one side, and two USB-A ports (1 A and 2.1 A) on the other.
In addition, the two 10 Wp panels charge two power banks (66 Wh) directly.
Uses: recharging headlamps, surveying and photographic equipment, a computer, powering an astronomical mount…
And did you get enough power out of those panels and battery?
Yes. That’s enough. I only use the computer for a little while in the evening to write up the day’s notes. We don’t run our head torches flat every day either.
Tip: arrange the panels so they don’t shade one another. You can also tilt them so that they produce the maximum possible output throughout the day, from east to west. This may be important during the low-yield season (November to February in the Northern Hemisphere).
Here, the panels have just been set up for the photo. What’s more, it’s in the tropics, at 16°S. Ideally, you put a stake in the ground and prop the panel against it so that it’s perpendicular to the sun. You turn the panel manually during the day to follow the sun’s path.
Nice. I always get stressed out by small setups, but sometimes it’s just enough :wink:
I once had an astronomical mount with a 1 kWh battery too. It was mostly a lot to lug around, but the battery wasn’t even 10% depleted.
For astronomy, I use an iOptron SkyTracker travel mount. It has low power consumption, so I power it from the 12 V output of one of my power banks. I do astrophotography with a camera body and a standard lens. A camera battery lasts two hours. I recharge them with a Pixo-C universal charger plugged into the power bank’s USB output. No problem keeping everything going all night.
In France, I have an AS-GT mount. I power it in the same way, at 12 V from the same power bank. I also have a Lacerta MGEN-3 autoguider (rated at 1.2 W). No problems.
The camps last 10 days (plus two days travelling there and back, when we don’t have much electricity).
