at the end of part 1 of the previous thread, it was already becoming apparent that the solution we thought we had found might not hold up. This has now been confirmed. After the system ran without errors for some time, the problem has returned, i.e. the Smart BMS does not allow the batteries to be charged. Below is the current situation in bullet points, followed by two questions:
- the Smart BMS does not allow the batteries to be charged; in the ConnectApp it says:
“Charging allowed: No” - the Smart BMS does not indicate an error, either in the ConnectApp or via the status LED
- when the batteries are connected to a smallBMS, the smallBMS signals a “Temp or OVP” error
- the “Temp or OVP” error can be traced to one battery using the smallBMS
- in the ConnectApp, both batteries show normal temperatures and cell voltages; the batteries are balanced and ready for use, i.e. there is no indication of a temperature or overvoltage problem
- if only the battery without the fault is connected to the Smart BMS using the communication cables, the Smart BMS allows the batteries to be charged (“Charging allowed: Yes”)
- the faulty battery has barely noticeable mechanical damage to the insulation on one of the communication cables
- a break in one or more wires in the communication cable as a result of the mechanical damage can be ruled out
- a short circuit between wires in the communication cable as a result of the mechanical damage cannot be ruled out, but neither can it be confirmed
- the faulty battery was opened, and the electronic components on the PCB were checked for visible signs of electrical overload caused by a short circuit between the wires in the communication cable: there is no visible damage
- Question 1: Why doesn’t the Smart BMS status LED flash 3 times every 4 seconds to signal a
“Temp or OVP” error? This would have pointed the troubleshooting in a different direction from the start. - Question 2: Can the PCB installed in the battery be ordered as a spare part, and if so, where?
Best regards!
