After updating to 3.50~15 only half solar forecast
After updating to 3.50~15 the system shows a significant lower solar forecast. In the morning it was about 90kWh and now after updating only 41kWh.
The weather is very good and the hours with high solar power are in the afternoon at my system. So I think 90kWh will be easily reached today.
@dfaber Iā€™m at ~13 and my solar forecast is also reduced to ca 50%. One hour ago the forecast was correct.
This is unrelated to the beta. Production sites experiencing it.
No problem for me both my systems are unaffected and forecasts the same now as they did before updating to 3.50~15.
Not everyone is affected. A vrm change made earlier is being rolled back which should address it while the problem is determined.
