I have a multiplus ii 2x120 in an RV with an Onan QG7000 generator. In my current set up, when on shore power, I have the multiplus set to 50 amp but when connected to the generator I need to lower that to 10 amps to prevent overloading the generator. Can I use the input current limit control assistant to automatically change the input voltage to 10 amps when the generator is running (I can just tap off the hour meter for a 12v signal).
Related topics
| Topic | Replies | Views | Activity | |
| MultiPlus-II 6K5 with generator, minimum input current | 12 | 285 | April 20, 2026 | |
| 48v Multiplus-II input current limit from AC: arbitrary minimum threshold? | 2 | 1195 | June 13, 2025 | |
| Multiplus ii 12|3000|120-50 input current limit | 8 | 935 | June 5, 2025 | |
| Multiplus II 120/3000/24 Smart Shunt, CERBO GX Honda EU3000is Pass through and immediate charging | 5 | 363 | September 13, 2024 | |
| AC-in on Multiplus ll 2x120 | 3 | 103 | January 26, 2026 |
