1 MultiPlus II 48|8000|110 inverter
3 150|60 charge controllers
3 sets of photovoltaic panels, for a total of 12 kW
5 Pylontech US5000 batteries
1 Ekrano
…and I need to add a Victron NS EV Charging Station.
I’m not sure where the cable to connect to the wallbox should start, from the inverter or from the electrical panel.
How about sharing a schematic and photo of your system?
Normally the output of the inverter is going to go to a circuit breaker box with 40A breaker(s), depending on number of phases in your setup. There’s different ways of configuring the whole system, and not enough info in your post. So @MikeD gave good advice.
