From the MultiPlus II, I like to read out the momentary DC input voltage and DC current. Do you know if:
- If this DC input voltage is measured? And the DC current?
- How to get access to these values? (I scanned the NodeRed nodes and did not see a way access these values)
I need the values per MultiPlus II which are now connected in 3-phase mode.
The idea is to calculate the power loss in the wiring between the batteries and the multis. The battery BMS does supply these momentary values.
Thanks in advance for your support,
Bert
