Access rear panel of CCGX mounted in MPPT 150/100
I have Victron EasySolar Inverter 48/5000/70 MPPT 150/100 Color Control system. The system was installed without network access for the CCGX module. I want to add WiFi dongle to the CCGX but am unsure of how to access the back of the CCGX. Do I need to remove the front panel of the inverter to gain access? If so, can I do this with the system running?
No don’t do it with the system running. There are live boards behind there things can get exciting fast. (Make sure you have an extra set of hands to help.)
You definitely need to lift off the front panels. One is removed (lower one) and th top one you you just need to lift up to gain access as there are quite a few cables attaching it to the components inside.
Thanks LX!
