AC load part missing V3.70~74
In latest firmware box AC load in top right corner is missing
No issues here with the latest beta, I am running v3.70~74 on a Raspberry Pi connected to my MP II 48/10000/140.
I do suffer from the problem with my Modbus over TCP connection to my SolarEdge system dropping.
If I connect the SolarEdge to my Home Assistant using WillCodeForCats excellent integration it is 100% solid.
Hi @Kruszkog, thanks for reporting.
Can you please share a list of devices that are connected to your system, e.g. a screenshot of the VRM Device list?
Devices list below.
I don’t have inverter maybe this is the problem?
Yes in the latest beta if you dont have an inverter or other energy meter etc the ac box is gone.
I have energy meter but Shelly Pro 3em
Do you plan to add it as in previous version or force to use victron inverter?
Currently I use shelly meter because it is compatible with my microinverter (Ecoflow)
I can add “basic ac loads” but in details see power summary from each device but in the box 0 watt
Can you give some answer please?
Yes, currently, having solely a grid meter is not enough to show the AC Load. I will discuss internally, if we can change that. As a workaround: You are already using Node-RED virtual nodes, so what you could do is adding one virtual AC Load device via Node-RED, which is enough for the AC Loads to show.
The problem is, I have vertual AC Load but it is not shown in the device list of AC Load box (screen), have also Shelly devices and are shown there but still 0 W as total in the box (screen)
