Hello All,
I’ve recently been given 20 6v 260ah ups batteries that have reached the end of their acceptable life for ups use but still have a lot of life left in them. I’m trying to configure a system to integrate my existing 5.7kW SolarEdge PV using an AC coupled hybrid configuration. I only want to use one Quattro if possible to keep the cost down. Is there a way to wire in the split phase grid power and split phase PV ac output into one 48v/10000VA Quattro? I’ll have a Cerbo, and VM-3p75 metering for both the grid and PV. Plus all the required disconnects and fusing and shunt.
